banneduser Posted August 22, 2003 Posted August 22, 2003 Hi All,I've got an Optrex 16433-CEM LCD fo 10$ :) and I don't know how to connect it can you help me? I have connected pins except these:Display datasheetNo. Symbol Level Function1 VSS - Power Supply (0V, GND)2 VCC - Power Supply for Logic3 VEE - Power Supply for LCD Drive4 RS H / L Register Select Signal5 R/W H / L Read/Write Select Signal H : Read L : Write6 E H / L Enable Signal (No pull-up Resister)7 DB0 H / L Data Bus Line / Non-connection at 4-bit operation8 DB1 H / L Data Bus Line / Non-connection at 4-bit operation9 DB2 H / L Data Bus Line / Non-connection at 4-bit operation10 DB3 H / L Data Bus Line / Non-connection at 4-bit operation11 DB4 H / L Data Bus Line12 DB5 H / L Data Bus Line13 DB6 H / L Data Bus Line14 DB7 H / L Data Bus Line15 EL - Power Supply for EL16 EL - Power Supply for ELCore LCD pinsD7D6D5D4D3D2D1D0ERWRSV0VsVdB+B-And how should I connect that backlight thingy ??? I don't even know what backlight type is it. And witch side should be on top? It looks that silver side should be on top as its pins then are in right direction to fit there. Thanks
pilo Posted August 22, 2003 Posted August 22, 2003 huummm I can't wee why you didn't wire all the connector?VCC -> Vd and VEE->V0fir the backlight : Where did you get it pleasE?????? I'm very interested in that!!!! and is it a led backlight? of ot's EL backlight you'll need a converter...
smashtv Posted August 22, 2003 Posted August 22, 2003 That's an EL backlight. The white side is probably the light up side, and you do need a convertor to drive it. Have fun!Smash
banneduser Posted August 22, 2003 Author Posted August 22, 2003 Thanks. :)Now can you say how to make that EL inverter? ;)
banneduser Posted August 23, 2003 Author Posted August 23, 2003 Hi,I found something at http://www.geocities.com/talkingelectronics/EL-Inverter-Project-P1.htmlbut it is for 3v and I can't find its components here. Are there more EL Inverter's circuts ???
pilo Posted August 23, 2003 Posted August 23, 2003 I am maybe wrong but, it camera's flash, those you use only once, there's this kind of circuit
banneduser Posted August 25, 2003 Author Posted August 25, 2003 No it's an inverter for lighting EL plates and wires. I found everything except the transformer. Who can help me building an EL inverter or I'm only with EL here??? And what should display my LCD when it's connected with core without PIC? Thanks
pilo Posted August 25, 2003 Posted August 25, 2003 what should display my LCD when it's connected with core without PIC?nothing!Who can help me building an EL inverter I think the easiest way is to buy an EL inverter...
banneduser Posted September 2, 2003 Author Posted September 2, 2003 But the biggest problem is that I cannot find any here in my country :'( . So I think I can build it ;) . But I don't know how. Can somebody help me? Thanks
pilo Posted September 2, 2003 Posted September 2, 2003 have a look on ebay, sometimes there's one to buy.I don't know if it's always the same output volatge... 160V?
LO Posted September 3, 2003 Posted September 3, 2003 Yeah Pilo; Im sure I have seen somewhere a circuit from a disposable camera used to do this job I think it was in a magizine; they were talking about going to photo-labs to get the old camera cases, pull the circuit board out make one small mod and you had an inverter ???Cant remember which publication tho!
