TK. Posted October 14, 2010 Report Posted October 14, 2010 See snapshot: Translation: support for control surfaces based on iOS Apps that utilize the OSC protocol. MBSEQ is prepared! :) Best Regards, Thorsten.
Davo Posted October 15, 2010 Report Posted October 15, 2010 So, if you can run MBSEQ on an iPad, how do you get midi connectivity?
TK. Posted October 15, 2010 Author Report Posted October 15, 2010 So, if you can run MBSEQ on an iPad, how do you get midi connectivity? With this one: http://svnmios.midibox.org/listing.php?repname=svn.mios32&path=%2Ftrunk%2Ftools%2Fosc_midi_proxy%2F Alternatively I can use MBSEQ as a proxy (it provides the same functions) and forward OSC events to any MIDI device - either via USB or UART based MIDI. But this wasn't the point - the real MBSEQ has an ethernet interface, it could control the Logic Functions via OSC now instead of MIDI for higher flexibility. Best Regards, Thorsten.
sineSurfer Posted October 15, 2010 Report Posted October 15, 2010 so... mbSEQ hardware or mbSEQ in iPad as Logic controller?
