BlackTXandY Posted November 18, 2010 Posted November 18, 2010 Hi, I need to know if there's a way to program the pic based core to work with some DINs, AINs and DOUTs modules to make a Keyboard like "Axiom25"... something with 37 keys, pitch and modulation wheels, some pads, some pots to control things like echo, reverb,etc.. and a nice design :D Im now building the project of Traktorizer (the page is out now) and if it works good, i will try something like this Axiom25... Thanks for all!
Hawkeye Posted November 18, 2010 Posted November 18, 2010 welcome on board! it would be possible, but if it should be the same, then buy the axiom, will cost you way less time and money... you would also have to find a suitable keyboard.... for that cost you can get a full usb-based midi keyboard controller... on the other hand, if you plan for some extras, you can roll your own. But it takes time, and as far as I see, some PIC coding which most people on this planet don´t do for fun ;). I´d recommend to buy a decent midi master keyboard and then think of additional features you need...
BlackTXandY Posted November 18, 2010 Author Posted November 18, 2010 Here in Brazil the cost of this axiom is about R$ 850,00 (something arround $460,00), I really prefeer to build my own keyboard (pic based core is something arround $25,00 and each module are beetween $10-$15). And I can customize the layout and design too hehehe... But thanks for the reply :D
J Martins Posted November 19, 2010 Posted November 19, 2010 Here in Brazil the cost of this axiom is about R$ 850,00 (something arround $460,00), I really prefeer to build my own keyboard (pic based core is something arround $25,00 and each module are beetween $10-$15). And I can customize the layout and design too hehehe... But thanks for the reply :D ----------------------------------------- Sorry for the portuguese on this reply for the english speakers. It's clear my english is that bad. I'd prefer reply to him in our native language.;) ----------------------------------------- E ae BlackTXandY Cara, se eu não me engano não existe nenhum aplicativo para o Core8 (Core c/ PIC) que lide com velocity, after touch, etc. O que é essencial em um teclado para uma performance profissional. Se você quer só eventos Note ON / OFF, dai sim pode usar o aplicativo Midibox64, Midio128, ain64_din64_dout128 . Fora isso só tem um código fonte , que pelo que eu li no readme.txt, lida com velocity mas escaneia apenas um pequeno número de entradas, e é recomendado apenas para drumpads, não alcançando escanear uma matriz de teclas de um teclado. De qualquer forma, dê uma olhada neste aplicativo Se você for bom programador em C ou Assembly talvez consiga fazer um aplicativo para isso ;) De outra forma recomendo mesmo comprar um axion25. Pense, você vai ter que comprar oitavas do seu teclado, que são bem difÃcieis de se achar sem ser em grandes centros urbanos como São Paulo e Rio de Janeiro, matriz de contatos, e vai ter uma bela de uma trabalheira para montar um circuito de fiação (impressa) para essas teclas, ou ainda reaproveitar um teclado usado e mesmo assim ter muito trabalho para reaproveita-lo e adptá-lo a plataforma Midibox. Não estou te desencorajando, mas te digo, vai perder um bom tempo e algum dinheiro com alguns erros inevitáveis em um projeto de tal complexidade. Mas a escolha é sua. Um Axion25 não é tão caro assim. No mercado livre tem uns bem baratos, novos e usados, e até no ebay, mesmo arcando com custos de importação sai em conta. Eu mesmo estava precisando de um teclado e comprei um controlador Michael por R$300. Ele só vem com 3 oitavas com teclas grandes e sensÃveis a velocity, porque pitch bend, modulation, knobs, botões é bem fácil se ter em uma caixa a parte com um PIC, não? ;)
BlackTXandY Posted November 22, 2010 Author Posted November 22, 2010 (edited) rapaizz... não eh que eh uma boa ideia mesmo... usar um teclado simples e adicionar os controles com outro core... valew mesmo KnoBall. Ah sim, quanto ao sensor de velocity e aftetouch eu pensei em usar encoders em cada tecla, e para fazer as oitavas eu podia cortar em acrilico mesmo, fica um resultado muito bom. Mas agora vc me deu uma luz hehe... vou procurar um teclado simples no ML. Edited November 24, 2010 by nILS Please don't fullquote
