rossdeluxe Posted November 18, 2010 Report Posted November 18, 2010 I am looking for someone to assemble SEQ V4. The work will be contributed. thank's in advance. Quote
Hawkeye Posted November 18, 2010 Report Posted November 18, 2010 (edited) 5K€, you can have mine... ok, just joking, would not sell it for that low amount of money... :-) it is really not that difficult to build your own. Search this section, there may be hints and descriptions what to buy and how to build it ;-) and, it is great to make music on hardware that you´ve built yourself... just consider it a preparation... other musicians have to exercise their voices, tune their pianos, we have to use a soldering iron - so what... Edited November 18, 2010 by Hawkeye Quote
rossdeluxe Posted November 18, 2010 Author Report Posted November 18, 2010 5K€, you can have mine... ok, just joking, would not sell it for that low amount of money... :-) it is really not that difficult to build your own. Search this section, there may be hints and descriptions what to buy and how to build it ;-) and, it is great to make music on hardware that you´ve built yourself... just consider it a preparation... other musicians have to exercise their voices, tune their pianos, we have to use a soldering iron - so what... Thanks Hawkeye. I'm planning to build myself. I just have to look for the pieces, you can give me some advice? Here in Italy is not easy to find these pieces, however I decided to build it myself with the help of a friend who understands more than me. :yes: Quote
Hawkeye Posted November 19, 2010 Report Posted November 19, 2010 you could always follow my but it´s custom and therefore a little bit more work will also still take some time to complete it... lots of work now. Quote
rossdeluxe Posted November 19, 2010 Author Report Posted November 19, 2010 you could always follow my but it´s custom and therefore a little bit more work will also still take some time to complete it... lots of work now. you are great! :hug: your tutorial is very useful but can be applied to the construction of SEQ V4?? Quote
Hawkeye Posted November 19, 2010 Report Posted November 19, 2010 (edited) yes, it will be a seq v4 - will probably take a few more weeks before it is completed, though :) i would recommend you order a core32 pcb and kit and 3x din and 3x dout pcb + parts kits from smashtv (links in the tutorial) to be on the safe side... Then you can start to solder the core32 which is the heart of your seq v4. This is already described in the tutorial. Edited November 19, 2010 by Hawkeye Quote
Astazou Posted November 22, 2010 Report Posted November 22, 2010 Then you can start to solder the core32 which is the heart of your seq v4. This is already described in the tutorial. Well, if you're completely new to electronics, maybe you'd better "train" on the DINs & DOUTs which are said to be more resilient (and far less expensive than the CORE if you break something). I'm in the process of midifying an old analogue organ console, started with the pedalboard and keyboards rewiring, up now to about 400 desolder, rewire and resolder of the contact pins, and still not happy with the results. I imagine I'll train some more on the keyboards before I start on the PCBs :laugh: Quote
rossdeluxe Posted November 22, 2010 Author Report Posted November 22, 2010 yes, it will be a seq v4 - will probably take a few more weeks before it is completed, though :) i would recommend you order a core32 pcb and kit and 3x din and 3x dout pcb + parts kits from smashtv (links in the tutorial) to be on the safe side... Then you can start to solder the core32 which is the heart of your seq v4. This is already described in the tutorial. is what I will do. begin to assemble the STM32 is the first step. I ask you something legendary Hawkeye?? where the card is securely and led encoders, where you order?? :ike: Quote
Hawkeye Posted November 22, 2010 Report Posted November 22, 2010 (edited) sorry, did not understand "the card is securely" leds will be most likely special-format dual color leds from digi-key or reichelt, but choose anyone you like rotary encoders (not potentiometers) are alps stec encoders from reichelt For a detailed list of proven-to-be-working control surface parts, have a look at Wilbas page regarding his control surface: http://www.midibox.o...seq_parts_guide Also read the hardware options section of the mbseq manual on ucapps.de to understand which modules you need and how they are interconnected: http://ucapps.de/mid..._manual_hw.html Good luck! Edited November 22, 2010 by Hawkeye Quote
rossdeluxe Posted November 28, 2010 Author Report Posted November 28, 2010 (edited) sorry, did not understand "the card is securely" leds will be most likely special-format dual color leds from digi-key or reichelt, but choose anyone you like rotary encoders (not potentiometers) are alps stec encoders from reichelt For a detailed list of proven-to-be-working control surface parts, have a look at Wilbas page regarding his control surface: http://www.midibox.o...seq_parts_guide Also read the hardware options section of the mbseq manual on ucapps.de to understand which modules you need and how they are interconnected: http://ucapps.de/mid..._manual_hw.html Good luck! perhaps I have not explained well. I talked about the PCB's. I solved it by the bulk order recommended by Wilba. You build a seq 4?? thanks H Edited November 28, 2010 by rossdeluxe Quote
Hawkeye Posted November 28, 2010 Report Posted November 28, 2010 yes, if the gods allow it, it will be a seq v4 eventually ;-). that is, if the cables to the control surface are not too long... TK. said it might be the case... if that happens... yes... we will see ;-) Quote
rossdeluxe Posted November 29, 2010 Author Report Posted November 29, 2010 yes, if the gods allow it, it will be a seq v4 eventually ;-). that is, if the cables to the control surface are not too long... TK. said it might be the case... if that happens... yes... we will see ;-) I have to start from scratch. if I need to contact you, ok? :console: Quote
Hawkeye Posted November 30, 2010 Report Posted November 30, 2010 I will help, if I can. But I suggest, that you just use this thread for asking questions. Most people are very helpful around here. Have fun with your project! Quote
rossdeluxe Posted December 1, 2010 Author Report Posted December 1, 2010 I joined the bulk order for the kit of the PCB but I have not received any response, you know how it works? Quote
Hawkeye Posted December 3, 2010 Report Posted December 3, 2010 (edited) you just need to wait... make sure, that your forum profile contains your valid email address... at some time Wilba will contact you... If you are planning to order in SmashTvs shop (AVI Showtech), wait a little as rumours say, that he might have Wilbas Control Surface PCB for sale later ;-). All in all, you need these things: * Core32 + parts kit (SmashTV) * Wilbas SEQ-V4 Control Surface PCB (SmashTV or Wilba) * Wilbas Control Surface parts (Wilba) * two 2x40 character displays (e.g. Ebay) * a sequencer case (use your own or look out for a case bulk order) * and a CNCed Aluminum Frontpanel (FPE/Schaeffer AG). Bye, Peter Edited December 3, 2010 by Hawkeye Quote
rossdeluxe Posted December 3, 2010 Author Report Posted December 3, 2010 you just need to wait... make sure, that your forum profile contains your valid email address... at some time Wilba will contact you... If you are planning to order in SmashTvs shop (AVI Showtech), wait a little as rumours say, that he might have Wilbas Control Surface PCB for sale later ;-). All in all, you need these things: * Core32 + parts kit (SmashTV) * Wilbas SEQ-V4 Control Surface PCB (SmashTV or Wilba) * Wilbas Control Surface parts (Wilba) * two 2x40 character displays (e.g. Ebay) * a sequencer case (use your own or look out for a case bulk order) * and a CNCed Aluminum Frontpanel (FPE/Schaeffer AG). Bye, Peter ok, i'm wait! :sleep: Quote
