vintagestar Posted November 29, 2010 Posted November 29, 2010 Hi, I have problem with the sammichSID Encoder, when I turn the knob there is no response. I couldn't change the patch by turning the knob. I want to buy a new encoder. Does all encoders works for replacement? I can't find any 16mm detented rotary encoder. Any suggestion? Regards, vs
pingosimon Posted November 29, 2010 Posted November 29, 2010 I found this: http://www.mouser.com/ProductDetail/Alpha-Taiwan/RE160F-40E3-20A-24P/?qs=yA6kp8fx8Y7zlmuFqx9z8g%3d%3d But let Wilba or someone confirm it, or better yet, give you a part number. Also: lulz, the "Customers who bought this also bought" section is pretty much a parts list for the MB-6582.
Wilba Posted November 29, 2010 Posted November 29, 2010 I just bought 652-PEC16-4220FN0024 which is the new Bourns version, will trial them in the current batch of sammichSID kits. I think it would be easier/cheaper if I just post you a new one, if you're not already buying stuff from Mouser.
vintagestar Posted November 29, 2010 Author Posted November 29, 2010 Hi Wilba and pingosimon , Thanks for the replies. Is 652-PEC16-4220FN0024 the right part number? It looks like the pin is 90 degree with the shaft in the photo. Have you confirm this part can be use with the sammichSID? What about the old encoder? What model is it? Regards, VS
Wilba Posted November 29, 2010 Posted November 29, 2010 I think it would be easier/cheaper if I just post you a new one
