nuke Posted December 3, 2010 Posted December 3, 2010 (edited) ...might be interesting for some of you... i stumbled across this site innerclock so i ran a little test with my MBSeq808-Build...120 bpm, rimshot each quarter...and ended up like this: 22.029|22.072|22.075|22.025|22.077|22.028|22.079|22.030| 22.077|22.027|22.071|22.030|22.075|22.030|22.071|22.031| ...so the largest distance between two quarters is 52 samples...the tested 808 is 87 (on their site) so a 1,18 ms drift compared to 1,97 ms... what i was thinking of is , what cause the drifts? (not that i´m not satisfied with the results) would it be an improvement when the two 33pF caps (C1, C2) will be matched as close as possible? ...this is just a guess...since i´m noob when it comes to electronics (but learning everyday ;)) nik Edited December 4, 2010 by nuke
latigid on Posted December 4, 2010 Posted December 4, 2010 ? Faster update rate for the trigger pulses ??
nuke Posted December 4, 2010 Author Posted December 4, 2010 (edited) ? Faster update rate for the trigger pulses ?? ...mmm....is this just a guess?...or do you think its the only way to avoid the jitter?...i assume then its more a programming aspect rather than selecting components, right? ok...why i ask is because i thought of building such a "sync-lock" on my own (i would buy this- but it´s soo expensive for "just" a midiclock...also like to have more midiouts, like they announced with the cinq-lock)...so when it depends on "just" programming, thought it may be possible with a pic (maybe even with mios ) to get a stable samplebased midiclock via a trigger input... i searched this forum and also the www and stumbled across several projects (pic and arduino-based), but they all seam to be kinda "dead", not further developed... :unsure: the clockboxproject is great, but it also is heavily dependent of a stable midiclock from its source...would be great to have such a trigger-feature added to this... cheers, nik Edited December 4, 2010 by nuke
waveformer Posted December 4, 2010 Posted December 4, 2010 ...might be interesting for some of you... i stumbled across this site innerclock so i ran a little test with my MBSeq808-Build...120 bpm, rimshot each quarter...and ended up like this: 22.0029|22.0072|22.0075|22.0025|22.0077|22.0028|22.0079|22.0030| 22.0077|22.0027|22.0071|22.0030|22.0075|22.0030|22.0071|22.0031| ...so the largest distance between two quarters is 52 samples...the tested 808 is 87 (on their site) so a 1,18 ms drift compared to 1,97 ms... what i was thinking of is , what cause the drifts? (not that i´m not satisfied with the results) would it be an improvement when the two 33pF caps (C1, C2) will be matched as close as possible? ...this is just a guess...since i´m noob when it comes to electronics (but learning everyday ;)) nik And how did you measure this ?
nuke Posted December 4, 2010 Author Posted December 4, 2010 (edited) And how did you measure this ? did u read the article on the innerclock site posted above?...they describe the procedure there... i put the mb808seq as master at 120bpm with a rimshot each quarternote...in soundforge i sampled 4 measures...so 16 rimshots in total...the distance between two rims should be exactly 22.050 samples @ 44.1Khz...the results are posted above...i know its not 22.0029 ...should read 22.029 and so on, with a zero less (my fault, was a copy paste error :ahappy: ) <- corrected the readouts Edited December 4, 2010 by nuke
