serge Posted September 2, 2003 Report Share Posted September 2, 2003 Hi,I uploaded pay.c's mb64 sysex files for rebirth on my site. You can download it at http://users.pandora.be/sdrsite/sites/serge/vmidibox/dev/presets/rebirth_midibox64_pay_c_sysex.zip(see description below)Thanks pay.c !Have fun,SerRebirth Control Sysex - Filesby pay.cThe files are based on Rebirth 2.0 Standard Mapping. I tried to achieve a Rebirth Screen to MB image, but, as you can guess, within Rebirth this is very hard. So I only got near that.I use a 4-line LCD! If you dont, pls change this! All Pots are in Snap Mode. I only used 32 buttons since my own MB has only 32. Like always: If you turn a Pot, you can see what it is assigned to (if nothing is on the LCD the Pot is disabled).Here are the Specs: Rebirth Ctr.1:Pot 1-16: Synthi 1 and its mixerPot 17-32: Synthi 2 and its mixerPot 33-48: 808 Drum Levels, Instr. Selection and its mixerPot 49-64: 808 Drum ParametersButton 1-12: Enable Mix/Dist/PCF/Comp of Synth 1, synth 2 and 808Button 13-16: Enable PCF/Delay/Dist/Comp SectionButton 17-20: (MB64:F1-F4) Disp Menu, Bank Menu, Decr Bank, Incr BankButton 21-24: MB64 Navigation ButtonsButton 25-29: Transport Bar RebirthButton 30-31: not assignedButton 32: Switch between Select Pattern Mode/ Program Synth Mode Rebirth Ctr.2:Pot 1-16: 909 Upper Row of "Pots"Pot 17-32: 909 Lower Row of "Pots"Pot 33-48: PCF Ctr, Dist Ctr, 909 Instr. Selection and its mixerPot 49-64: Dely Ctr, Comp Ctr, Master VolumeButton 1-4: Enable Mix/Dist/PCF/Comp of 909Button 5-15: not assignedButton 16: Master Section Comp EnableButton 17-32: The same as in Rebirth Ctr.1I hope these files are helpfull for some of you. For bugs/greets/comments or whatever mail at:pay.c@web.deYou can also contact me on the Midiboxforum (pay.c).Greets@all and Midiboxx RuLeZ!!!01.09.03 pay.c Quote Link to comment Share on other sites More sharing options...
