My newly built SEQ v4 has an annoying problem. All 5 of the LEDs above the transport controls stay lit constantly regardless of play, pause, stop, etc... I have taken the unit back apart and examined the core, the cabling and the control surface with a microscope and see nothing wrong. I apologize if i am being thick here, but i just don't see any reason for this behavior. Is this most likely a build/hardware issue or software issue (running V.4.Beta24 3.5.65) A search here and at uCApps turned up nothing.
Any help would be appreciated. Thanks!!
Check the LED assignments in the Hardware file on the SD card. Ensure that the LEDs are assigned to the correct shift registers.
Hope this helps
Tim.
