meneerzweerbeer Posted May 28, 2011 Posted May 28, 2011 Hello, Quick question: I can't figure out how to assemble the back of the DIN4X... Suppose to add 4 jumper wires and 4 caps but the pictures in the tutorial are too shady and Im too much a noob to do it without. Does anyone have a picture of the back of a DIN4X? If it can help I can upload a picture of my attempt, maybe somebody can point out where I went wrong KEEP YOUR SOlDERING IRON HOT! =)
ilmenator Posted May 28, 2011 Posted May 28, 2011 Which version of the board are you using? From Mike's or from SmashTV's (the latter one has a version number on it)?
meneerzweerbeer Posted May 29, 2011 Author Posted May 29, 2011 Version 2 DINX4 From Mikes Midizeite There is like a landingstrip/surface soldering on the back, I attached the jumperwires on those But if somebody has a picture it will clear up my mind, Ill take pictures in a minute
meneerzweerbeer Posted May 29, 2011 Author Posted May 29, 2011 Here I soldered them all the same Can you tell me if this is correct?
