It would be really nice if someone could point me in the right direction to my problem.
I got some problem with my lcd on my MB-6582, suddenly it only displays black boxes. What to do?
Could it be something on the basebord i need to fix? Or is it time to buy a new display?
I have built the baseboard and cs and everything have been working good.
Voltage checking, OK.
Testtone, OK
Uploading mios, OK
Playing some nice sounds, OK. Startup sound is working.
I have tested it with another lcd, same thing there. ( that one could be broken, last time i tested it was a year ago )
I use a c64 psu and it works good, and tested the voltage on the baseboard again and everything looks good.
I appreciate all the help i can get,
Thanks
/Rimfrost
Edited by Rimfrost
did you try adjusting the contrast pot? failing that, maybe you could try plugging your lcd into a different core.
thanks for your reply nebula.
I have now tried all cores and adjusting the contrast pot, the lcd is working on core 3-4 and black boxes on core 1-2.
So it seams so be something wrong on core 1-2, i will look in to it later.
After taking a good look at the baseboard i found that 2 of the crystals were broken, brown/black stuff under them. Replaced one for a little test and now it's working :)
But i don't know why they broke, does anyone have a clue?
Hi, maybe you overheated them during the soldering stage?
It could be so, i tried to be careful and not overheat anything. Next time i will be extra carefull :)
Right now i am happy that everything works, order new crystals today so hopefully i can replace them next week and completly finish this nice project:)
