HI!
is anybody out here who knows something about old DOS Tracker for the OPL 3(or 2 or 1) Chip on i.e. Aztech Soundgalaxy.
My problem is to find such a tracker which is able to be synced by a midi clock or could send such an clock ???
MORITZ
  • 2 months later...
HI!
As I remember, there was possibility to control 'Ed Lib tracker' by midi keyboard connected thru mpu401.
In this case it is probably possible to use soundcards joystick port as a midi interface and play adlib sounds from Cubase or other sequencer.
I don't remember if it was possible to use arpagios or other more complicated sounds ? I have to try it next week  ;D
Here is a place, when You can find some old FM Trackers :
http://www.astercity.net/~malf/trackers.html
(I do not know if any of them works with midi - let us know if You find one.
BTW. It could be quite interesting to build synth module (like SID BOX) with OPL chip. With additional effects / filters it could generate interesting polyphonic sounds.
Regards,
maniac
