Touch sensor compatability -->
Hi Thorsten...
r u sayin instead of pulling the +5v from the AINX module, to use a separate circuit that outputs +5v and connect that to the +5v leg of the touch strip to it... or can i can just ape the power supply section of the core module...
Nice1...
Dan
  • 2 weeks later...
No, the AINX4 module itself should still be supplied by the core module. Only the analog inputs can be optionally connected to other voltage sources. If you've a source which outputs 0-5V, just connect the output pin to one of the analog inputs.... don't forget to join the grounds!
