d2k Posted October 18, 2002 Posted October 18, 2002 Hi...Found this on a google mish...http://www.infusionsystems.com/products/touchmini.shtmlCan that touch sensor be used instead of a reg knob/fader...?Thanks...
TK. Posted October 19, 2002 Posted October 19, 2002 Sure, you just only have to build a circuit which outputs a control voltage of 0-5V. See also http://www.ucapps.de/midibox_ext.htmlAdditions to this page are welcome! :)Best Regards, Thorsten.
d2k Posted October 24, 2002 Author Posted October 24, 2002 Hi Thorsten...r u sayin instead of pulling the +5v from the AINX module, to use a separate circuit that outputs +5v and connect that to the +5v leg of the touch strip to it... or can i can just ape the power supply section of the core module...Nice1...Dan
TK. Posted November 1, 2002 Posted November 1, 2002 No, the AINX4 module itself should still be supplied by the core module. Only the analog inputs can be optionally connected to other voltage sources. If you've a source which outputs 0-5V, just connect the output pin to one of the analog inputs.... don't forget to join the grounds!Best Regards, Thorsten.
