Stigmata Posted September 15, 2003 Report Posted September 15, 2003 Hi there!!Just found out an bug in the J-synth I think...The Jsynth and the sid not respond the same playmodeJsynth=MONO SID=WTSJsynth=Legato SID=WTSJsynth=WT seq only SID=MonJsynth=Poly SID=PolyChristoffer
Stigmata Posted September 15, 2003 Author Report Posted September 15, 2003 Hi there!!Just found out an bug in the J-synth I think...The Jsynth and the sid not respond the same playmodeJsynth=MONO SID=WTSJsynth=Legato SID=WTSJsynth=WT seq only SID=MonJsynth=Poly SID=PolyChristoffer
TK. Posted September 15, 2003 Report Posted September 15, 2003 This is a known bug in the current firmware, see also:http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=troubleshooting;action=display;num=1060704667;start=0#0for the workaround.Best Regards, Thorsten.
