Sebo Posted November 18, 2011 Report Posted November 18, 2011 Hi: Recently I'm using more the clock output of the MIDIbox CV (firmware ver. 1.2a), and noted an anoying behaviour. My sequencer (SONAR) is sending MIDI Clock all the time (even when stopped), and MIDIbox CV y synced all the time, so is outputting Clock signal all the time, that's OK, when I hit start in my sequencer, the MIDIbox CV keeps outputting Clock, but not sync the division to the start of the sequencer. Let's say I configured the Clock of the MIDIbox to 24/12 ppqn, when I start the sequencer most times the clock is shifted from the the tempo of the sequencer. The shift could be anything between 1 ppqn and the division I set in the MIDIbox configuration (1/8 note in my example). How could I reset the counter in the MIDIbox CV when a MIDI start message arrives? Thank you. Quote
TK. Posted November 18, 2011 Report Posted November 18, 2011 This seems to be a bug, but unfortunately I've currently no access to my hardware. Please up this thread in 2 weeks if I haven't replied yet. According to the source code the divider should be reset on an incoming MIDI start event: movlw 0xfa cpfseq IRQ_TMP1, ACCESS rgoto CV_CLK_NotifyRx_NoStart CV_CLK_NotifyRx_Start clrf CV_CLK_DIVIDER, BANKED ; clear clock divider (!) rgoto CV_CLK_NotifyRx_Start_Cont CV_CLK_NotifyRx_NoStart [/code] but it seems that this doesn't work correctly anymore. Or can anybody confirm that it works at his side? Best Regards, Thorsten. Quote
Sebo Posted November 19, 2011 Author Report Posted November 19, 2011 Thank you Thorsten!!! Hope it can be solved :) Quote
Sebo Posted December 8, 2011 Author Report Posted December 8, 2011 Hi Thorsten: Did you look at the sync problem? I tried to look at the code but my programing skills are almost null. Thank you. Quote
TK. Posted December 11, 2011 Report Posted December 11, 2011 I wasn't able to reproduce this with Logic, but I noticed a missing feature: the divider wasn't cleared with a song position event. If Sonar doesn't send MIDI start, but a song position event instead, then this is the reason. Please try following version and give feedback: http://www.ucapps.de/mios/midibox_cv_v1_3.zip Best Regards, Thorsten. Quote
Sebo Posted December 12, 2011 Author Report Posted December 12, 2011 Thanks a lot Thorsten!!! I will try it in next few days and report back. Just a question: I always used MPASM to make the HEX file (I have to mod some things in the main ASM), can I still use it? Quote
Sebo Posted December 14, 2011 Author Report Posted December 14, 2011 Hi Thorsten: Problem solved. The clock is working great!!! Thank you very much!!! Quote
TK. Posted December 18, 2011 Report Posted December 18, 2011 Great! It's released now :) Best Regards, Thorsten. Quote
