gslug Posted November 20, 2011 Posted November 20, 2011 Having built my first LPC17 Core last night, I can't get it to work! I followed the instructions on the wiki, except that I did not seperate the debug board, but when connected to my computer (running Ubuntu), it is not detected. Both dmesg and lsusb give no indication that anything has been connected. A red LED (I presume the power LED) lights on the LPC board, but that's it. Any ideas? Thanks, Kevin
gomiboy99 Posted November 20, 2011 Posted November 20, 2011 (edited) Have you tried the LPC on its own (not connected to core PCB)? This is what Dmesg shows on my Ubuntu machine for the debug board: [ 368.584139] usb 1-2: new full speed USB device using ohci_hcd and address 3 [ 368.790167] usb 1-2: configuration #1 chosen from 1 choice lsusb shows : Bus 001 Device 003: ID 0471:df55 Philips I couldn't get eclipse to work on my machine as it's a rather old Toshiba but, once the bootloader was installed (using a windows machine) Mios Studio works ok. Tim. PS I think you have to program the bootloader via the debug port before the usb on the core PCB works. Edited November 20, 2011 by gomiboy99
gslug Posted November 20, 2011 Author Posted November 20, 2011 Thanks Tim, I have already programmed the bootloader - that part appeared to worked fine. The LPC17 module shows up when connected via the debug board, but not when connected via the core PCB's USB socket. Off to work now, but I'll have another play when I get back. I may try to re-flash the bootloader in case somthing whnt wrong there. Kevin
gomiboy99 Posted November 20, 2011 Posted November 20, 2011 Sorry, didn't quite understand the problem. I think this post will help: The debug board needs to be separated from the LPC board. You do not have to cut the debug board off but you will need to cut the tracks between the 2 rows of header holes. I hope that solves it. Tim
igi Posted November 20, 2011 Posted November 20, 2011 Hi there! Try touch JTAG connector (on debug interface side) with finger, this was work for me. ( before I separate LPC board) Best ragards, IGI
taximan Posted November 20, 2011 Posted November 20, 2011 Here is a previous post from the seqv4l page Posted 10 November 2011 - 19:38Hiya, I found a strange little quirk with my lpc1769 board......here are the details. If I do not seperate the two halves of the lpc board before placing it on the core board,the lpc will not boot corectly,I spent a good few hours looking for dry joints etc in the header pins to no avail. However if I twisted the board ever so slightly the thing would boot up....it turned out my fingers were brushing against J5 of the debugging board making the thing boot up.....confused is an understatement...lol. Anyhow I put my other lpc17 (already seperated) on the same core board and it fired up 10/10....hmm only difference was the debugging board was not attached to this one.......so I attached it via the sockets suggested at ucapps.....aaaaa progress...this board would not boot up with the debugging board attached either........unless I touched J5 on the debugging board. Took the debugging board from the new lpc17 placed it in the core and bingo....it worked. So,looking at the ucapps tutorial on the lpc17 it seems that I have done everything that I should have but it seems the debugging board has to be removed for the lpc17 to work........or as is usually the case have I missed something? Anyhow....all is good now but I thought this might save someone else a bit of hair tugging. cheers Paul
gslug Posted November 20, 2011 Author Posted November 20, 2011 (edited) Thanks everyone! I decided to be brutal and separated the boards with a pair on tin snips. I now have a working core module.:) Edited November 21, 2011 by gslug
taximan Posted November 21, 2011 Posted November 21, 2011 Snips!!! seriously? I would be crapping myself. I used a junior hacksaw (very fine blade) and was worried about using that...lol. cheers Paul
gslug Posted November 21, 2011 Author Posted November 21, 2011 I initially tried to cut the traces, but with the pins already soldered on, I could not put the board down on a flat surface, so gave up after a few minutes. I was a tad worried about using snips, but I have cut strip board with them before without any problems. It worked really well - a nice clean cut, with the holes intact on both sides of the cut. Kevin
