Duggle Posted December 7, 2011 Posted December 7, 2011 Hi All, I've connected a RTCC (real time clock calendar) chip MCP79410 to IIC bus STM core32. I'm able to set it and read it o.k It keeps time when the core is not powered (by way of supercap). Question is: Is there a way to use this time with SDcard so that files created have the correct timestamp? Ive been playing with the SD card Tool application to see how file accesses are done. thanks
ilmenator Posted December 7, 2011 Posted December 7, 2011 Interesting! I don't have an immediate answer to this, but the underlying API is FatFs, and there is at least a command to change the date/time stamp, see the FatFs website.
Duggle Posted December 8, 2011 Author Posted December 8, 2011 Interesting! I don't have an immediate answer to this, but the underlying API is FatFs, and there is at least a command to change the date/time stamp, see the FatFs website. Yes, the set_timestamp(..) example works. Just have to make sure this gets called when data in the file is changed. Thanks!
ilmenator Posted December 8, 2011 Posted December 8, 2011 (edited) Hey, good to hear! Could you tell us how exactly you connected the RTCC, and what you did to set it properly? Does it account for leap years and daylight saving time changes automatically? For how long does it keep the correct time / date if not powered up? Hehe, too many questions... Edit: well, never mind, it's all in the device's documentation which can be found here. Thanks, ilmenator Edited December 8, 2011 by ilmenator
ilmenator Posted December 9, 2011 Posted December 9, 2011 Cool, thanks! Have you got an estimation of how long the supercap will hold enough charge to keep the RTCC running? Which model are you using? The original design suggests the use of a battery.
Duggle Posted December 11, 2011 Author Posted December 11, 2011 Cool, thanks! Have you got an estimation of how long the supercap will hold enough charge to keep the RTCC running? Which model are you using? The original design suggests the use of a battery. I'm using the device without unique ID feature MPC79410. The data sheet says 700nA to power in standby (Vbat=1.8V) so I think a Lithium coin cell is the best for most use cases. I calculate the 0.9F supercap will keep the clock running for only 36days. A coin cell may easily have 100mAhrs that's >100,000 hrs, well over 10 years.
Duggle Posted December 11, 2011 Author Posted December 11, 2011 Here's some code to access this device: (at least the RTCC features) MCP79410.h #ifdef __cplusplus extern "C" { #endif extern void RTC_init(); extern char* RTC_GetTimeString(); //read time "hh:mm,dd-mm-yyyy" extern char IsTimeStrFormat(char * ts); //validate TimeString format extern void RTC_SetFromTimeString(char* ts); //set time "hh:mm,dd-mm-yyyy" extern void RTC_PutForward1Hour(); //put time forward an hour (i.e -> Daylight Savings) extern void RTC_PutBack1Hour(); //put time back an hour (i.e-> NON Daylight Savings) extern char RTC_IsSet(); //has the RTCC been set? #ifdef __cplusplus } #endif MCP79410.c #include <mios32.h> #include <string.h> #include <time.h> #include "MCP79410.h" #define I2CADDR 0x6F #define VbatEnableReg 3 #define VBATEN 3 #define ST 7 #define reg_seconds 0 #define msk_seconds 0x7F #define reg_minutes 1 #define reg_hours 2 #define msk_hours 0x3F #define reg_day 3 #define msk_day 0x07 #define reg_date 4 #define reg_month 5 #define msk_month 0x1F #define reg_year 6 #define reg_control 0x07 #define SQWE 6 #define OUT 7 #define SRAM_START 0x20 void RTC_WrReg(u8 r,u8 d){ u8 sub[2]; sub[0]=r; sub[1]=d; s32 x=MIOS32_IIC_Transfer(0,IIC_Write,I2CADDR<<1,sub,2); x=MIOS32_IIC_TransferWait(0); } u8 RTC_RdReg(u8 r){ u8 d; d=r; s32 x=MIOS32_IIC_Transfer(0,IIC_Write,I2CADDR<<1,&d,1); x=MIOS32_IIC_TransferWait(0); x=MIOS32_IIC_Transfer(0,IIC_Read,I2CADDR<<1,&d,1); x= MIOS32_IIC_TransferWait(0); return d; } u8 Int2BCD(int x){ //return integer as two decimal digits char low=x%10; char hi=(x/10)<<4; return hi|low; } int BCD2Int(u8 bcd){ //Convert two BCD digits to Integer int h=10*(bcd>>4); return h+(bcd&0x0f); } void RTC_init(){ char regval; regval=RTC_RdReg(VbatEnableReg); //read dont change other bitfields regval|=(1<<VBATEN); //enable backup supply RTC_WrReg(VbatEnableReg,regval); regval=RTC_RdReg(reg_seconds); //read dont change other bitfields regval|=(1<<ST); //start the osc RTC_WrReg(reg_seconds,regval); RTC_WrReg(reg_control,((1<<SQWE)|(1<<OUT))); //enable squarewave 1Hz on MF Pin. Requires pullup on MFP } char* RTC_GetTimeString(){ //return timestr static char s[24]; char secs,mins,hrs,date,mth,yr; secs=RTC_RdReg(reg_seconds); secs&=msk_seconds; mins=RTC_RdReg(reg_minutes); hrs=RTC_RdReg(reg_hours); hrs&=msk_hours; date=RTC_RdReg(reg_date); mth=RTC_RdReg(reg_month); mth&=msk_month; yr=RTC_RdReg(reg_year); sprintf(s,"%02X:%02X,%02X-%02X-20%02X",hrs,mins,date,mth,yr); //TimeStr return s; } char IsTimeStrFormat(char * ts){ //"hh:mm,dd-mm-yyyy" char result=0; if (strlen(ts)==16) result=1; else{ MIOS32_MIDI_SendDebugMessage("TimeStr format:\"hh:mm,dd-mm-yyyy\" bad length-%d-",strlen(ts)); return 0; } if ((ts[2]==':')&&(ts[5]==',')&&(ts[8]=='-')&&(ts[11]=='-')) result=1; else{ MIOS32_MIDI_SendDebugMessage("TimeStr format:\"hh:mm,dd-mm-yyyy\" bad format"); return 0; } return result; } void TimeStr2tm(struct tm* T, char* t){ //fill in struct tm with an input timestr T->tm_hour=(t[0]-0x30)*10+(t[1]-0x30); T->tm_min= (t[3]-0x30)*10+(t[4]-0x30); T->tm_sec=0; T->tm_mday= (t[6]-0x30)*10+(t[7]-0x30); T->tm_mon= (t[9]-0x30)*10+(t[10]-0x30)-1; //from 0 T->tm_year= 100+(t[14]-0x30)*10+(t[15]-0x30); T->tm_wday=0; T->tm_isdst=0; } char RTC_IsSet(){ char yr; yr=RTC_RdReg(reg_year); return (yr>0x10); //unset RTC has year==01 } void RTC_PutForward1Hour(){ //put time forward an hour (i.e -> Daylight Savings) char hrs=RTC_RdReg(reg_hours); char x=hrs; x&=~msk_hours; //clear hours field hrs&=msk_hours; //clear non hours field(s) hrs=BCD2Int(hrs); ++hrs; //inc hours as integer if (hrs==24) hrs=0; hrs=Int2BCD(hrs);//store as BCD hrs|=x; //set control bits RTC_WrReg(reg_hours,hrs); }; void RTC_PutBack1Hour(){ //put time back an hour (i.e-> NON Daylight Savings) u8 hrs=RTC_RdReg(reg_hours); u8 x=hrs; x&=~msk_hours; //clear hours field hrs&=msk_hours; //clear non hours field(s) hrs=BCD2Int(hrs); if (hrs==0) hrs=23; else --hrs; //dec hours hrs=Int2BCD(hrs);//store as BCD hrs|=x; //set control bits RTC_WrReg(reg_hours,hrs); }; void RTC_SetTime(struct tm* T){ char x,mins,hrs,date,mth,yr; mins=Int2BCD(T->tm_min); //load and convert to BCD hrs=Int2BCD(T->tm_hour); date=Int2BCD(T->tm_mday); mth=Int2BCD(T->tm_mon+1); //months start from 0 yr=Int2BCD(T->tm_year-100); //year counted from 1900 //dont worry about seconds RTC_WrReg(reg_minutes,mins); x=RTC_RdReg(reg_hours); //read all x&=~msk_hours; //clear data bitfields hrs|=x; //set control bits RTC_WrReg(reg_hours,hrs); RTC_WrReg(reg_date,date); x=RTC_RdReg(reg_month); x&=~msk_month; mth|=x; RTC_WrReg(reg_month,mth); RTC_WrReg(reg_year,yr); } void RTC_SetFromTimeString(char* ts){ //"hh:mm,dd-mm-yyyy" struct tm T; TimeStr2tm(&T,ts); RTC_SetTime(&T); }
TK. Posted December 11, 2011 Posted December 11, 2011 Nice! :) Under modules/fatfs/src/diskio.c you will find the get_fattime() function which is currently not implemented: DWORD get_fattime(void) { /* 31-25: Year(0-127 org.1980), 24-21: Month(1-12), 20-16: Day(1-31) */ /* 15-11: Hour(0-23), 10-5: Minute(0-59), 4-0: Second(0-29 *2) */ return 0; } [/code] I could declare it as "weak", this would allow you to implement an alternative version in your driver (a weak function will be replaced by your implementation if it's linked into the project) Best Regards, Thorsten.
Duggle Posted December 15, 2011 Author Posted December 15, 2011 Hi TK, I've experimented by modifying the header declaration to: DWORD get_fattime (void) __attribute__((weak)); I'm confused however, as the declaration appears in ff.h (not diskio.h) and your implementation is defined in diskio.c Anyhow, I'm finding that your implementation is getting executed, not mine, which is implemented in my app.cpp I'm sure what I need to do here? Did I get the declaration syntax right? thanks.
Duggle Posted December 16, 2011 Author Posted December 16, 2011 I think this article demonstrates how the attribute works: Article I'll have another try.
Duggle Posted December 16, 2011 Author Posted December 16, 2011 The declarations and definitions in the repo need to be appropriately modified for this weak override business to work. The only way I can seem to get it to work is to comment out TK's implementation of get_fattime(). Anyhow it's working fine! This is in my app.cpp extern "C" DWORD get_fattime(void) { return RTC_GetFatTime(); } and this is added to the RTCC driver routines listed earlier: DWORD RTC_GetFatTime() { DWORD FatTime=0; char secs,mins,hrs,date,mth,yr; secs=RTC_RdReg(reg_seconds); secs&=msk_seconds; mins=RTC_RdReg(reg_minutes); hrs=RTC_RdReg(reg_hours); hrs&=msk_hours; date=RTC_RdReg(reg_date); mth=RTC_RdReg(reg_month); mth&=msk_month; yr=RTC_RdReg(reg_year); FatTime|=BCD2Int(secs)>>1; FatTime|=BCD2Int(mins)<<5; FatTime|=BCD2Int(hrs)<<11; FatTime|=BCD2Int(date)<<16; FatTime|=BCD2Int(mth)<<21; FatTime|=(BCD2Int(yr)+20)<<25; return FatTime; } /* 31-25: Year(0-127 org.1980), 24-21: Month(1-12), 20-16: Day(1-31) */ /* 15-11: Hour(0-23), 10-5: Minute(0-59), 4-0: Second(0-29 *2) */
TK. Posted December 18, 2011 Posted December 18, 2011 I just have changed diskio.c, so that get_fattime is handled as a weak function now. Could you please check, if your function is now able to overload the "weak" implementation without source code change? Best Regards, Thorsten.
Duggle Posted December 19, 2011 Author Posted December 19, 2011 Thanks Thorsten, it works fine. The only thing I had to do was put in #ifdef __cplusplus extern "C" { #endif .. #ifdef __cplusplus } #endif around the function declarations in ff.h for c++ compilation. It would be good (for c++ coders) if headers get committed this way. Cheers
TK. Posted December 19, 2011 Posted December 19, 2011 I don't want to change the original header files for such a purpose, because the modification would get lost if I (or somebody else) would update to a newer version, and the next guy who would try to compile your application would get confusing compile errors. You could just wrap the #include statements in your .cpp file instead: extern "C" { #include <ff.h> #include <diskio.h> } [/code] This has the same effect. Best Regards, Thorsten.
Duggle Posted December 19, 2011 Author Posted December 19, 2011 You could just wrap the #include statements in your .cpp file instead: extern "C" { #include <ff.h> #include <diskio.h> } This has the same effect. Great, I'll do this.
