Hi there!!
Just playing around with my SID its sooooo cooool!!  ;D
Just a few questions about the logic env.
Im not into Hex or Bit..
For example the waveform parameters you got 8 zeroes.
if i turn it to: 00000001 is that the same as Bit 0:Triangle
and if i got    00000010 is that bit 1:saw ??
The example in the txt file you got  an example 05h = 5 = triangle & pulse how i turn that into logic env.??
Thanks!
Christoffer
Hi Christoffer,
yeah, the MIDIbox SID *is* cool - yesterday I made my first real song with 2 SIDs (stereo) and I'm very satisfied with the result. :D
The binary numbers are a little bit tricky. Don't "translate" them into hex or decimal values, just deal with them like with flags (or think about switches, which can be turned on or off).
So, a saw sound is:
  00000010
(Bit 1 is "switched on")
Triangle and Pulse together:
  00000101
(Bit 2 and 0 are "switched on")
Sync sound:
  00100001
(Bit 5 for sync and bit 0 for triangle is set)
Btw.: Sync and Ringmodulation are only working together with Oscillator 3. OSC3 is the "master", OSC1 and/or OSC2 the slave. More details can be found in the 6581 specification. A good start:
OSC1 Waveform: 00100010
OSC2 Waveform: 00010000 (off)
OSC3 Waveform: 00000010
Now increase the Transpose value for OSC1 and you will hear the difference. A well living sound can be achieved by assigning the velocity to the Transpose CC of OSC1 (CC17).
Make it more fat - enable the second oscillator:
OSC2 Waveform: 00100100
detune it and and assign a LFO to the pulsewidth
