Duggle Posted January 15, 2012 Posted January 15, 2012 I'm making a modified Bootloader to (hopefully) enable upload of apps from all UARTs (i.e UART0,UART1,UART2). Anyhow, I've hit a problem with make of the (unmodified) Bootloader: First of all these compiler warnings: Creating object file for mios32_midi.c /MIOS32prj/mios32/trunk/mios32/common/mios32_midi.c: In function 'MIOS32_MIDI_SYSEX_Cmd': /MIOS32prj/mios32/trunk/mios32/common/mios32_midi.c:1494:3: warning: implicit declaration of function 'BSL_SYSEX_Cmd' /MIOS32prj/mios32/trunk/mios32/common/mios32_midi.c: In function 'MIOS32_MIDI_SYSEX_Cmd_Query': /MIOS32prj/mios32/trunk/mios32/common/mios32_midi.c:1577:4: warning: implicit declaration of function 'BSL_SYSEX_ReleaseHaltState' Then an error with the perl generator part: ------------------------------------------------------------------------------- Application successfully built for: Processor: STM32F103RB Family: STM32F10x Board: MBHP_CORE_STM32 LCD: dummy ------------------------------------------------------------------------------- arm-none-eabi-size project_build/project.elf text data bss dec hex filename 16088 80 5784 21952 55c0 project_build/project.elf make[2]: Leaving directory `H:/MIOS32prj/sw/Controller/Bootloader' mv project_build/project.bin project_MBHP_CORE_STM32.bin perl gen_inc_file.pl project_MBHP_CORE_STM32.bin mios32_bsl_MBHP_CORE_STM32.inc mios32_bsl_image mios32_bsl process_begin: CreateProcess(NULL, perl gen_inc_file.pl project_MBHP_CORE_STM32.bin mios32_bsl_MBHP_CORE_STM32.inc mios32_bsl_image mios32_bsl, ...) failed. make[1]: Leaving directory `H:/MIOS32prj/sw/Controller/Bootloader' make (e=2): The system cannot find the file specified. make[1]: *** [MBHP_CORE_STM32] Error 2 make: *** [MBHP_CORE_STM32] Error 2 **** Build Finished **** Are the compiler warnings a problem? I'm not sure whats going on with the perl part. I'm assuming the generated *.inc file is necessary for apps to be built with, so that they are able to be loaded by the new bootloader? Thanks
TK. Posted January 15, 2012 Posted January 15, 2012 The warnings can be ignored. For the perl part I fear that it will only work under Linux or MacOS. Expert tip: you could install Ubuntu on a virtual machine, such as Virtual Box: https://www.virtualbox.org/ By putting the MIOS32 svn tree on a shared drive, the Windows based MIOS Studio version can access the new build! :) Best Regards, Thorsten.
Duggle Posted January 15, 2012 Author Posted January 15, 2012 Thanks for the advise! It sounds like a big investment of time because I've hardly used Linux. I don't imagine that I will be compiling many bootloaders. Is there a way I can hack a cludge into the perl script to get me going? (even if it only works for this one project!)
TK. Posted January 16, 2012 Posted January 16, 2012 What happens if you call this command line directly: perl gen_inc_file.pl project_MBHP_CORE_STM32.bin mios32_bsl_MBHP_CORE_STM32.inc mios32_bsl_image mios32_bsl If this doesn't help, just write down the required changes and I will create the binary for you. Best Regards, Thorsten.
Duggle Posted January 16, 2012 Author Posted January 16, 2012 That's a great offer, thanks Thorsten, HOWEVER, the install of perl on this machine is BROKEN (perl not found).The invocation within the makefile leads to a terse error message. (Funny because I used the perl scripts to compile banks for my old Midibox64 just early last year....) Firstly I'll reinstall and report back!!!
Duggle Posted January 16, 2012 Author Posted January 16, 2012 (edited) Yup, perl not in path. Project makes all the files. I'll have to edit the relative paths in the makefiles because I've copied the bootloader source directory to another location. I'll end up putting the modified bootloader in all my STM32 cores so that apps get compiled with the right (the same) *bsl*.inc which is for the modified bootloader. Next task is to flash and test the bootloader. Edited January 16, 2012 by Duggle
