Hi, great projects here and many thx for sharing .
I have a problem because my laptop don't have a gameport i try to upload MIOS with USB CABLE EMU 1X1 but isn't work.
The CORE 8 has a PIC18F452 burn with Brenner8 seems to be ok .When I press START to load the MIDI MIOS hex file , the midi msg of CORE stops and it take a 15-20 minutes to complete the loading bar...
after that restarting and the corepic same regular midi msg send. Everything seems OK because on ther Rx and Tx of the pins of PIC its blinking a LED , but won't loading via MIDI USB cable.
so.. What kind of cable or bootstap should to use ?
Oh!... why mine?!!!... :) ok , let's build MBHP_USB_PIC18F2550_(on stock) V1 or MBHP_USB_PIC with IIC module with PIC 18F452 (must I buy) ?
Thank you very much!
Yes , GM is the best , but in my country finally don't find to buy ,and I made it with PIC 18F2550 to upload MIOS ! 3 hours to work and 3 seconds to flashing COREPIC. THKs Once again .
