albpower2seq4sid Posted March 2, 2012 Posted March 2, 2012 (edited) ... I don't really know but I have my own ( recent ) experience in this way with the OPL3 board, and I want to share it. After I published the pictures of my FM board, happy with the new sounds ( on audio channels 1-2), I test the channels #3 and #4 and no sound at all!! :sad: then I try some things like to reflow the tin joints, to shorten the flat cable, test_interconnection software and here there was a weird thing happened: when I hit the DO and DO# keys ( in sequence ) a "click" was heard on #3 and #4 channels ( the same thing on #1 and #2 ) then I thought the four channels could be right, then I remembered i recompiled the firmware with the option "AOUT_NG" enabled and this cause some upload errors, so I thought "could it be the recompiled firmware the problem in this case? I thought it due to the following reasons: I changed channel (to #3 and #4) on Ensamble menu and nothing happens ( Only #1 and #2 working ) I set no audio channel at all and sound continues on #1 and #2 Then I download the compiled hex version ( v1 ), Upload it with MIOS STUDIO and... Crystal and beatiful sound on #3 and #4 channels!! :) But at first some "symptoms" were that similar to what were described (0.28 V on pin 22 C/D; 3.62 V on pin 21 A/B ) in this post: Well, only a curiosity... but may be it could be helpful... I don't know... Edited March 2, 2012 by albpower2seq4sid
Gilesjuk Posted March 2, 2012 Posted March 2, 2012 There's mention on the Wiki about not having the wires between the core and the OPL board too long. http://www.midibox.org/dokuwiki/doku.php?id=home:project:midibox_fm See "Control Cable Timing Issue".
albpower2seq4sid Posted March 2, 2012 Author Posted March 2, 2012 There's mention on the Wiki about not having the wires between the core and the OPL board too long. http://www.midibox.org/dokuwiki/doku.php?id=home:project:midibox_fm See "Control Cable Timing Issue". Ok, I followed that link and read it. What I noticed ocurred testing control lines with test_interconnection program.
