Gilesjuk
95 -
Everything posted by Gilesjuk
What happens if you asked for some PCBs to be shipped by Tk and some to by shipped by you Nils? Only I have my 4 chips from Tk and 2 5x5 PCBs, but I've heard nothing about the other two PCBs. It's no big deal as it will take me a while to build them all :)
The normal OPL board uses 12v and -12v OP amps. Which means building a more complex PSU.
LCD only lights up, after installing MIOS, Shortcut?
Gilesjuk replied to Lauchi's topic in Testing/Troubleshooting
PIC Core? it has a regulator and rectifier so it is pretty tolerant. Excess voltage is burned off as heat, so it can be worth trying to supply the minimum you need. I have a 7V AC transformer connected to mine. But if your PSU can't supply the current needed for the backlight then it won't light up. I would check the A and K connections of the LCD with your multimeter in continuity mode, being an LED it will pass current one way and not the other way. But if you get no reading both ways then the LED may have popped. You should get the backlight at the very least as that's a simple circuit. -
Is your power source up to the job? the backlight does need a few mA of power, the rest of the circuitry isn't demanding in power. -
Cool. Glad you got it going. An OLED display is next on my list, although it may go in the MB6582 first. I put one in my PreenFM and they are seriously impressive.
You can control the LED brightness with PWM. But three LEDs in one package is still three LEDs, you need extra circuitry.
Are you sure you have the cable connected to the core the correct way? there's two ways it can go on and both tend to light up the display. -
This is the guide to follow: http://www.midibox.org/users/jim_henry/building_a_midibox_lcd_cable.pdf -
Okay. Well the LCD wiring is easy to get wrong. I suggest double checking it? -
When turning the core on it asks for you to upload MIOS to it if it isn't already loaded. You may only have the bootloader programmed on your PIC chip, so you won't see a ready message or the copyright message. This explains what you will see: http://www.midibox.org/dokuwiki/doku.php?id=mios -
You might want to read this? http://joemaller.com/1424/worst-component-ever/
output of sid low in volume main output fine though
Gilesjuk replied to scottsober's topic in Testing/Troubleshooting
You mean the combined output of all the SIDs is low but the individual outputs are fine? -
Some of the joints look like the solder hasn't flowed onto the pad properly. Look as them from the side and they'll look round like a toffee apple or something. They should look volcano shaped. You're using lead-free solder right? (only it looks dull, unlike 60/40 lead solder which is shiny).
The SID chip itself has a set number of features that both support, but just like C64 composers all had their own replay routine. Each device controlling the SID has its own features implemented in their firmware. It's not impossible to salvage some settings from sysex dumps, but it would require quite a bit of work.
Perhaps people don't turn down the pot before first switch on? meaning it could be set really high on first test.
Where can I find latest MIDIbox SID Synth firmware?
Gilesjuk replied to brokenchip's topic in MIDIbox SID
The latest version is always in the MIOS 8 download section: http://www.ucapps.de/mios_download.html -
I've just taken delivery of a Mascot 9983 PSU. It is a 12v 0.5A linear regulated PSU and it works fine with the sammichSID. No display flicker or noise. I had to change the plugs though. But that's a simple task :) the lead with the stripe is the positive.
The one's I linked to are perfect, they're the right dimensions and there's no issue of quality. The only downside is the buttons are a sort of dark grey/brown colour. Which against black at least makes them slightly more visible.
Do you have 2.039 of MidiBox SID on your Sammichs? only there was a bug stopping patches being received in "common" sysex format. It is fixed in 2.040. Not sure if it is related to this editor thing though :)
It depends how fast they switch :) many switching supplies create noise or cause the display to flicker.
Green screen as in green backlight and black text? or the inverse green text on black background?
Great. Works a treat.
He passed away yesterday :( http://www.forbes.com/sites/davidthier/2012/04/09/computer-legend-and-gaming-pioneer-jack-tramiel-dies-at-age-83/ I'm sure many of us had a C64. It was my first real computer.
There's only one thing that can die and that's the backlight. It's typically a white LED and it can be replaced. The rest of the display is powered from a different set of connections.
Yeah, I bought a kit from someone who hadn't built it. But I have 8580s.
