Spirit Posted April 8, 2012 Report Share Posted April 8, 2012 Hello again. i have made my Midibox 64. 1x Core 2x Doutx4 2x Dinx4 2x Ainx4 1x LCD screen Now i only connected the LCD and Dinx4 module. after some strugeling i also have MIOS on it and MB64. all from this page http://www.ucapps.de/mios_download.html But if i Plug in the power everything seems fine only then it Keeps sending random note's? so i wondering is this normal, and how can i stop it. i just like to send a CC# Note if i Press a Button or rotate a Encoder? i'm allready searching for 2days now but i Cant find anywhare a Solution or a Explanation? i can only find this on this page: http://www.midibox.org/users/tor_arne/midibox64_walkthrough/connect.html " Now flick the power button and use MidiOx to log your incoming MIDI events. If everything's working you should see your screen fill with MIDI messages. This is because the PIC is receiving lots of random voltages which it believes to be MIDI controller messages. In the LCD you should now see a menu (if it's blank try your contrast pot)." But it does not explain Way and how to Stop it? Kind regards, spirit Quote Link to comment Share on other sites More sharing options...
TK. Posted April 8, 2012 Report Share Posted April 8, 2012 Hi, unused analog inputs have to be clamped to ground to avoid random events, see also this document: http://www.ucapps.de/mbhp/auaimbctg.pdf Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
Spirit Posted April 9, 2012 Author Report Share Posted April 9, 2012 Yeah! thanks TK i will try that. i did allready thought it was something like that, but could not find it anywhere. kind regards, spirit Quote Link to comment Share on other sites More sharing options...
Spirit Posted April 9, 2012 Author Report Share Posted April 9, 2012 and a other quastion. if i use Midibox 64 editor i cant save anything? /spirit Quote Link to comment Share on other sites More sharing options...
