Hola Comandante64,
this is a no-name switching power supply - that means it might introduce some noise into the audio path if its switching frequency is not high enough. Cheap PSUs like that have a tendency to use lower switching frequencies (but buying an expensive one is not a guarantee for high switching frequencies either).
The answer to your question is that no-one will know for sure. Try it out, it will be powerful enough, and if it turns out to be noisy then look further. At 8 Euros it's not a big loss, but be prepared for a disappointment.
Saludos, ilmenator
