so I want to build a simple 16x4 BLM for programming drums with and i would like it to connect to my seq v4L, would it work? i've been looking through the used interconnections and it seems that it needs to use J5B, which is already in use by the v4L control surface, is there anyway to work around this? anyone? (and by anyone i mean TK) ;]
edit: or will i need another core module to run the BLM? then just interface the seq and blm via midi?
-ajax
Edited by Ajax
Looking at the docu I would say that you cannot connect a classic 16x4 BLM.
Should it turn out to be possible: I am in the process of ordering a prototype board for the classic 16x4 which is still supported by SEQ V4, and based on the very nice Marquardt 6245 series of switches. Once I know the design is working I'll have some PCBs to share. PCB size is roughly 13,2" x 3,87".
