Posted (edited)
Pin #7 of the Shift Register #4 of a DOUTX4 module is outputting -0.73V (with LED connected) when it should light up.
All the other pins of all the other shift register work correctly (about 2.5V with LED lit)
I already checked LED polarity and resistors...
Edited by ytsestef
Found it, guys. It was the bridge. On mike's PCBs, there is a bridge for the last pin of the last Shift Register that should be soldered underneath the PCB. It had come off and the SR voltage never reached the resistor. I soldered it again and all is good :) Thanks
