I was reading through the WIKI and found the page showing a MBLC with 4 2x16 LCDs.
The connections seem straightforward enough, but the link to the firmware is broken. Does anyone have this firmware? or can help with this.
this is exactly what I'm looking for, but I don't have the necessary programming skills to implement myself.
Many thanks in advance,
Unfortunately I can't retrieve the URL of the old posting - it must be somewhere in the forum (I guess it was from MTE)...
On the other hand: I just remember that I personally adapted the MBLC firmware for 4 CLCDs while I visited doc some years ago, here is the source code and binaries:
http://www.ucapps.de/tmp/midibox_lc_x4.zip
The interconnections should match with the ones showed at the Wiki page.
Could you please confirm that it's working at your side? Then I will integrate the variant into the original firmware.
P.S.: the button/LED assignments are probably different - this will be solved once you've confirmed that the LCDs are working.
Marvellous !!!
Thank you for this, I will certainly confirm the results when I've built it and testing starts... though it may be some time
Once again, Many thanks
Rob
