Stewart Brownrigg Posted September 12, 2012 Posted September 12, 2012 Hi, Apologies for such a newbie question... I have completed building my MB-6582 and am slowly finding my way around the menu system. However, I did something really stupid early on, and cannot work out how to fix. In a session of which was mostly button mashing I think I managed to record a sequence of notes (c3 I believe). Now, whenever I put the box into play mode I get a long sequence of notes and I cannot fathom out how to erase them. Is there a way of completely wiping stored data? Cheers, Stewart
Janis1279 Posted September 14, 2012 Posted September 14, 2012 (edited) Hi, Are You meant to initialize to get the default patch ? From the Sid2 manual pages: the patch should be initialized to get a defined start. Press&Hold the SHIFT (formerly LINK) button and press the select button below "Ini" to get the default patch: Regards, Janis Edited September 14, 2012 by Janis1279
Stewart Brownrigg Posted September 18, 2012 Author Posted September 18, 2012 Hi Janis, Thank you for your reply. I have tried initialising the patch. I think what I have done is overwritten the Lead patch. I was having issues with my bank sticks - I was unfortunate to have a dud in bank A, so none of the bank sticks were getting formatted, or available. So, being new to midi and sequencing, I was saving to the init patch without realising. I guess now I just need to work out how to re-initialise my ini patch :( Cheers, Stewart
Hawkeye Posted September 18, 2012 Posted September 18, 2012 Hi, after initializing a patch, it is always on its default parameters, don´t worry, you can´t overwrite the "INIT" patch... It sounds like you are initializing a bassline instrument, which explains the long default "sequence" it plays... Try initializing another engine, like the Lead engine... http://www.ucapps.de/midibox_sid_manual.html Many greets, Peter
