EsotericLabs Posted September 18, 2012 Report Share Posted September 18, 2012 (edited) Hello, I was browsing the forum for info on how to send a midi file from a Mac/ PC to an Sd card in a midibox device. Either by accessing the card directly ( as if it were inserted into the computer) and just copy files to it in finder/ explorer; or to send it thru USB, have the core receive and store it; or some other way. I only found that its difficult /impossible to have two USB drivers accessing the port Simultaneously. Any thoughts on this one? Thanks a lot in advance! Edited September 18, 2012 by Martijn Quote Link to comment Share on other sites More sharing options...
ilmenator Posted September 18, 2012 Report Share Posted September 18, 2012 Have a look at how this is done in MBSEQ V4. There you have to explicitly enable PC access to the card in the menu. Once this is done, the SD card is visible as a USB storage device to the PC. Quote Link to comment Share on other sites More sharing options...
EsotericLabs Posted September 18, 2012 Author Report Share Posted September 18, 2012 (edited) Have a look at how this is done in MBSEQ V4. There you have to explicitly enable PC access to the card in the menu. Once this is done, the SD card is visible as a USB storage device to the PC.Thank you. I will dig into MBSEQV4. Edit: Only now I found the USB mass storage device example. I guess this says all I want to know.. Will try soon. Edited May 25, 2013 by EsotericLabs Quote Link to comment Share on other sites More sharing options...
