Hi forum, I cannot find anywhere to put this topic (apart from the obvious) so please excuse.
I have lots of chips: PIC16F877. mmmm m, I love these little chippy chappies.
I have the hex file for Midibox plus (16 pots).
Question: what must the CONFIG header (fuses) be set to in my programmer?
It being a hex file I don't know what the CONFIG should be, apart from high speed crystal.
I know its an old chip, I know Midibox plus is not MIOS based, I know everyones into big-ram chips,
but all I need is to burn the darn thing with the darn hex file.
If anyone can advise I would certainly appreciate their input.
best regards to all
here are the fuse settings:
They are also part of the .hex file.
This means that some programmers automatically will get the correct settings if they extract the information from the .hex file
  • 3 weeks later...
Thank you very much for that info Thorsten. I certainly appreciate it.
In passing (if you happen to have a spare moment) I was wondering:
does the Midi merger function (non-Mios software such as old midibox 64 etc) default to merger ON or OFF?
very best regards to you.
