I've tried to connect a T6963C.
but I can't get it to work.
What is the correct?
1]bootstrap loader.
2]mios_v1.4
3]lcd7_t6963c_h/v
4]midibox_sid_v1_5c_18f_stepC
or is the lcd7_t6963c_h/v the same as mios or midibox_sid
my question is what do I load into the pic and in witch order?
Thanks
Ok, you are always gonna need the bootstrap loader and MIOS. In order to test your display I would then load lcd7_t6963c_v.zip.
The Sid program does not support GLCD's. If your goal is to use it with the Sid, (I think) you will need to adapt the code to your display.
Justin
Yes, please check the driver application first. Thereafter you are able to integrate the driver into the SID application by replacing the app_lcd.inc file and by selecting the custom LCD like shown in USER_Init
Note that I never tried a T6963C display with the SID application, so when it doesn't work, it could be a bug in the driver which I cannot check (I don't own such a display).
Note also that the performance of the T6963C in horizontal mode is not high enough for the SID application, so you possibly have to take the veritcal mode
