Johey Posted January 1, 2013 Posted January 1, 2013 I recently assembled my MB6582 and now I'm trying to make music. Turns out that I am no fan of MIDI sequencers. Using Ardour in GNU/Linux. I would rather prefer a tracker style editor like ProTracker but for MIDI. Any suggestions? I've googled around, but I just found "tektrack" which has not been updated since 2004. I failed to compile it, but if that's my only option I might be able to fix that. I would like to have something compatible with Jack Audio Connection Kit in GNU/Linux, so I can sync it with Ardour and other MIDI tools.
Johey Posted January 1, 2013 Author Posted January 1, 2013 Is that what you are using for your great productions? It looks pretty much awesome. However, I forgot to mention I'm a libre software masochist. Can't use proprietary code. :)
Hawkeye Posted January 1, 2013 Posted January 1, 2013 Thx! I evaluated this tracker a while as I did some stuff on ProTracker/Amiga and FastTracker/PC back in the days... but nowadays for me nothing beats shutting down PCs/Macs and only using the almighty MBSEQ V4 hardware sequencer ;-).
Johey Posted January 1, 2013 Author Posted January 1, 2013 For real? The MBSEQ is usable enough to replace a MIDI sequencing pc application? Maybe I have to take a look into it then. :)
TK. Posted January 1, 2013 Posted January 1, 2013 You've to consider that I implemented a C64 based tracker ca. 20 years ago: http://noname.c64.org/csdb/release/?id=17422 MBSEQ is the continuation of my lifework... ;-) Best Regards, Thorsten.
Johey Posted January 2, 2013 Author Posted January 2, 2013 I have to try that one out then. If it's good, then MBSEQ must be so. :) (I've only used JCH Ed. on the C64.)
