Wurli100 Posted January 6, 2013 Posted January 6, 2013 Hi All, I'm building a 2-core MIDIO 128, and have everything up and running...EXCEPT, the two refuse to merge. Each core works perfectly independently, and I get the appropriate MIDI data output. I've created new .syx files for each core with merge enabled (I've tried only doing one at a time, as well), and even had a friend send me known-working .syx files for a 2-core setup like mine. Still nothing! Core 0 (outputting to the PC) works just fine when the two are daisy-chained, but core 1 does nothing.
latigid on Posted January 6, 2013 Posted January 6, 2013 Hi, are the device IDs set correctly (that is, if you are using 8-bit cores)?
TK. Posted January 6, 2013 Posted January 6, 2013 Hi, Core 0 (outputting to the PC) works just fine when the two are daisy-chained, but core 1 does nothing. does this mean, that Core0 is able to send MIDI events through the second core to your PC? Best Regards, Thorsten.
