Hi!
I am working on setting up the LRE8x2.ngc with my GLCD. I am trying to set it up so that I have the SCS menu at the bottom of the screen. That way I can have two sets of 2x8 encoder bar graph indicators at the top and middle of the screen. That way I can always have the SCS menu visible at the bottom, and always see 2 banks above it. I've been searching and experimenting on how to change the placement of the menu, but have had know luck. I'm using the standard SCS connected at J10.
I am such a programming novice that I really hope this question makes sense.
Cheers,
Alex
I will consider an appr. configuration option in one of the next releases.
With V1.018 the "SCS lcd_pos=<device>:<x>:<y>" command is available.
With:
SCS lcd_pos=1:1:7
the SCS page should be displayed at the two lower lines.
The menu isn't always visible, only after pushing the MENU button.
The reason is, that in the so called "main page" you could use this space for other meaningful output, such as the selected bank number.
