John E. Finster Posted February 9, 2013 Report Share Posted February 9, 2013 hi, i just got a bunch of resistor networks for the DIN modules, but they have 7 pins (6 resistors + 1 common pin). i can´t return them, so i am wondering. is it possible to cut off the unnecessary resistor or are the resistor networks destroyed if i do that? thanks and greets Quote Link to comment Share on other sites More sharing options...
ilmenator Posted February 9, 2013 Report Share Posted February 9, 2013 You can cut off the legs so that they don't require holes on the PCB. However, I don't think you can cut through the body of the device without destroying the remaining resistors. But then, why don't you just try? It's a cheap item, so even if you destroy one it won't hurt too bad... Quote Link to comment Share on other sites More sharing options...
John E. Finster Posted February 9, 2013 Author Report Share Posted February 9, 2013 thanks, i´m just gonna try that. i don´t care about the resistors, just don´t want to destroy any of the remaining parts that are attached to the resistors (like my midibox :rolleyes: ). Quote Link to comment Share on other sites More sharing options...
