Ajax Posted February 23, 2013 Report Share Posted February 23, 2013 Hello there everybody, I am about 95% to getting the virtual BLM osx application to work with my sequencer v4L. The issue that I am running into is that after setting the blm_port on the seq v4L through MIOS studio it seems to no longer pass sequencer midi information out through MIDI OUT 1, the blm is working with the sequencer, but I am unable to get it to send midi through the usual midi interface rather than the USB MIDI. I would use OSC but I do not have an ethernet port to solder to my LPC core. If anyone knows how to route this information through MIOS I would be very appreciative, thank you :] -ajax Quote Link to comment Share on other sites More sharing options...
TK. Posted February 23, 2013 Report Share Posted February 23, 2013 Hi Ajax, did you already try to set "BLM_SCALAR_Port 0x11", and to use the second USB MIDI Port for the communication with the virtual BLM? Or: could it be, that you don't see the 4 USB MIDI Ports after the installation of the latest MBSEQ V4L Release?If you only see a single USB MIDI Port: Did you already update the USB Interface definitions in the Audio/MIDI Setup of MacOS? Best Regards, Thorsten. Update: I just noticed, that the V4L update which enables 4 USB-MIDI ports hasn't been released yet. You will find it here: http://www.ucapps.de/mios32/midibox_seq_v4l_071_pre2.zip After the update, you have to:- enter the Audio-MIDI-Setup of MacOS- disconnect the core module from USB- delete the interface in the Audio-MIDI-Setup- connect the core module to USB again Thereafter you should see an interface with 4 USB MIDI Ports: Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
Ajax Posted February 23, 2013 Author Report Share Posted February 23, 2013 you rock tK, thanks for ruling the world, by the way, I want to be just like you, what should I start studying? :P -ajax Quote Link to comment Share on other sites More sharing options...
TK. Posted February 23, 2013 Report Share Posted February 23, 2013 by the way, I want to be just like you, what should I start studying? :Pelectronic magazines! :smile:There were much better ones than today at the time I started anno 1990, such as Elrad which was never replaced by something comparable.Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
