first, last ng version in conjunction with the new beta version of mios studio seems to have corrected some issues I had:
my midibox is now able to handle conditional events (with exact same ngc file used without modifications).
cool! :)
then, when I power cycle my midibox, I get a "READY" message at power on (like if "factory default" DEFAULT.NGC was loaded again".
"save default" will generate a DEFAULT.NGC file from values stored in RAM (also the ones which you haven't specified, but which are active - such as LED_MATRIX_PATTERNs)
Since the "LCD" command is directly processed from SD Card, and not stored in RAM (would be a waste of memory), it will get lost and therefore won't be stored.
There are two alternatives:
- either directly upload the DEFAULT.NGC file without using the "store" function
- or write the LCD command into the DEFAULT.NGR file:
if ^section == 0
  LCD "%C"
endif
