kpete Posted March 30, 2013 Report Posted March 30, 2013 Hi all, I am modifying the Midio128 V3 software for an organ project. This unit will add Midi voices to an existing Rodgers 840 electronic organ. I want to save my stop information in the EEPROM on the LPC board rather than on the SD card since it might not be available all the time. I understand how to add it to my build since Midio128 doesn't use it at all. My question is: Do I have to worry about any reserved addresses that might be used by things like the boot loader? And has this software been used in other projects and found to work? Pete Quote
TK. Posted March 31, 2013 Report Posted March 31, 2013 Hi Pete, the bootloader stores the configuration values in a special flash section to avoid any conflict. Which means, that the EEPROM is free for other purposes. A simple usage example for the EEPROM driver can be found here: http://svnmios.midibox.org/listing.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Fmisc%2Fusb_osc_midi_proxy%2F See presets.* The driver is included from the Makefile, and configured in mios32_config.h: // EEPROM emulation #define EEPROM_EMULATED_SIZE 128 // magic number in EEPROM - if it doesn't exist at address 0x00..0x03, the EEPROM will be cleared #define EEPROM_MAGIC_NUMBER 0x47114200 Note: it's called "emulation" due to historical reasons. For the MBHP_CORE_LPC17 module the external EEPROM. The magic number should be something different than 0x4711* (which is normally used by my own projects) - it's used to identify the data structure format inside the EEPROM (see presets.c) Best Regards, Thorsten. Quote
kpete Posted April 1, 2013 Author Report Posted April 1, 2013 Thanks for the information and the link Thorsten. Great stuff this MidiBox. There's so much to learn. Pete Quote
