ilmenator Posted March 31, 2013 Report Posted March 31, 2013 Hi, this might sound like a strange usecase, but I'll try to explain: Would it be possible to apply some of the EVENT_* parameters also to incoming MIDI events, but in a "reversed" way? E.g. I have a device that sends CC data depending on rotation speed and I want to transform that data into something else, say NRPNs: it is basically behaving like the enc_mode=00Speed, which makes transforming these events quite difficult interpretation-wise. Or am I just missing something here and it is easily achieved? Thanks, ilmenator Quote
TK. Posted March 31, 2013 Report Posted March 31, 2013 I could provide a special meta event for Inc/Dec value - in one of the future versions ;) Best Regards, Thorsten. Quote
ilmenator Posted April 1, 2013 Author Report Posted April 1, 2013 That sounds good! Actually, the C4 behaves like defined in enc_mode=Inc00Speed_Dec40Speed but that is probably the same on all Mackie Controls!? Quote
TK. Posted April 14, 2013 Report Posted April 14, 2013 The "emu_enc_mode" is available in v1.024 See also this configuration example: http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Fcontrollers%2Fmidibox_ng_v1%2Fcfg%2Ftests%2Femu_enc.ngc And this page for available modes: http://www.ucapps.de/midibox_ng_manual_ngc.html Best Regards, Thorsten. Quote
ilmenator Posted April 14, 2013 Author Report Posted April 14, 2013 This is great, thank you! I think there is something wrong with the Inc00Speed_Dec40Speed emu_enc_mode: right-turning (increasing) seems to work fine, but left-turning sets the value to 7F immediately, and that "locks up" the encoder / CC message until I save the .NGC file and thus init the NG app. Best, ilmenator Quote
TK. Posted April 14, 2013 Report Posted April 14, 2013 Yes, this mode probably needs some adjustments, the calculation for the incrementer doesn't look right. Is the Inc01_Dec41 mode working at your side? It's almost the same, just only the speed isn't considered. If it doesn't work: could you please find out, which CC values are sent exactly by your controller? Best Regards, Thorsten. Quote
ilmenator Posted April 14, 2013 Author Report Posted April 14, 2013 (edited) Yes, Inc01_Dec41 works. Attached is the MIDI implementation of the C4 Pro, the commands I'm after are on page 2, i.e. it sends: B0 00 01 B0 00 04 B0 00 08 B0 00 0C B0 00 0F B0 00 41 B0 00 44 B0 00 48 B0 00 4C B0 00 4F for increasing (upper block) and decreasing (lower block) values. Edit: attachment is too big, so I skip this... Edit 2: attachment is already. Edited April 14, 2013 by ilmenator Quote
TK. Posted April 14, 2013 Report Posted April 14, 2013 alright - with this pre-release the Inc00Speed_Dec40Speed should work correctly. http://www.ucapps.de/mios32/midibox_ng_v1_025_pre1.zip Best Regards, Thorsten. Quote
