Stephan_WE Posted April 22, 2013 Posted April 22, 2013 Hi, we try to connect our first button matrix to the midibox lpc. We have a DIN and DOUT Modul connected to a button matrix. Unfortunalty, we get only an event on some buttons. Some buttons don't show any reaction others create a lot of events. No real schema. How should we debug this. We soldered the diodes in the wrong direction. Can we fix this with "inverted_sel=1 and inverted_row=1" Br, Stephan
TK. Posted April 22, 2013 Posted April 22, 2013 Hi Stephan, if diodes are soldered in the wrong direction, you've to change the polarity of the pull-up resistors at the DIN inputs as well. They have to pull the signal to ground instead of 5V If you are using the original MBHP_DINX4 module, search here: http://www.ucapps.de/mbhp_din.html for the keyword "pull-down". If you are using the MBHP_DIO_MATRIX module (-> http://www.ucapps.de/mbhp_dio_matrix.html), just change the polarity with J6 Best Regards, Thorsten.
kpete Posted April 23, 2013 Posted April 23, 2013 (edited) Can't you just switch the cables between the Din and Dout boards that goes to the keys? Then the diodes will point in the right direction. Only problem might be that the keys won't send the right command. But this can be changed. Edited April 23, 2013 by kpete
Stephan_WE Posted April 24, 2013 Author Posted April 24, 2013 Thanks for the Feedback. We try that tomorrow. Best Regards Stephan
Stephan_WE Posted April 26, 2013 Author Posted April 26, 2013 Hi, we get now events BUT all buttons from one row show the same hw_id. Any Ideas whats wrong? Kind Regards Stephan [33721.009] MBNG_DIN_NotifyToggle(3, 1) [33721.010] [EVENT:3003] BUTTON hw_id=3 bank=0 fwd_id=0x4003 type=NoteOn value=127 label=^std_btn [33592.277] MBNG_DOUT_NotifyReceivedValue(4, 0) [33592.279] MBNG_DIN_NotifyToggle(4, 0) [33592.279] [EVENT:3004] BUTTON hw_id=4 bank=0 fwd_id=0x4004 type=NoteOn value=0 label=^std_btn [33592.283] MBNG_DOUT_NotifyReceivedValue(4, 127)
TK. Posted April 27, 2013 Posted April 27, 2013 Seems that the inversion flags haven't been set correctly Best Regards, Thorsten.
Stephan_WE Posted April 28, 2013 Author Posted April 28, 2013 Hi Thorsten, we don't understand this. We tried the DIN_MATRIX Command in all variants. We connected the DOUT pins to the Buttons and than to the cathode of the diode and than to the DIN Module. Our Command is DIN_MATRIX n= 1 rows=8 inverted=1 inverted_sel=1 inverted_row=1 sr_dout_sel1=3 sr_dout_sel2= 0 sr_din1= 0 sr_din2= 0 So I guess, we have to resold the Matrix completly. Br Stephan
TK. Posted April 29, 2013 Posted April 29, 2013 Hi Stephan, if the diodes are in the right direction, no inversion would be required. Neither for the selection lines, nor for the rows. Did you test this as well? Btw.: "inverted=1" and "inverted_sel=1" are actually doing the same. "inverted" only exists due to compatibility reasons. Best Regards, Thorsten.
