Stigmata Posted October 26, 2002 Posted October 26, 2002 I Get the computer MIDI OUT to M64 MIDI IN and the OUT to the SID working fine but not the M64 must I have an Merger or Independent MIDI interface for the SID??Seems like the SID not sending MIDI info from the M64.Peace!Christoffer
TK. Posted October 29, 2002 Posted October 29, 2002 Hi Christoffer,thats correct, I've disabled the MIDI merger in this firmware so that the SID module behaves like a common MIDI synthesizer.A temporary workaround: remove the optocoupler of the SID core module and connect J11:MO of the MB64 core with J11:MI of the SID core and connect the J11:Vs pins (ground) of both cores together. On this way the MIDI stream which is coming out of the MIDIbox64 will be routed to the MBSID and your PC.I will check in the next days if an activated merger causes performance problems in the MBSID firmware.Best Regards, Thorsten.
