Spirit Posted July 6, 2013 Posted July 6, 2013 (edited) hi TK i would like to have 2 features on he LPC.. First, is it possible to have more then ONE bank assigned to a EVENT_ this would i think reduce the pool event allocation for me ALLOT!!! Second, previous i have been busy with the Event_receiver and i could not assigne it to a BANK. can you still make this possible for me... :rolleyes: kind regards, Spirit Edited July 6, 2013 by Spirit
Duggle Posted July 7, 2013 Posted July 7, 2013 (edited) First, is it possible to have more then ONE bank assigned to a EVENT_ this would i think reduce the pool event allocation for me ALLOT!!! Can you explain this one some more? Normally without "bank=" the event responds in any bank, but presumably you are duplicating event definitions so that an EVENT_* corresponds to a group of particular bank# but not others? Edited July 7, 2013 by Duggle
Spirit Posted July 7, 2013 Author Posted July 7, 2013 your totaly right... and to give you a idee what i have done. https://www.dropbox.com/s/kh6ae5fl59hmjb4/VIDEO0054.mp4 this is my first Beta testing version to see if everything would work how i like to have it.. and if i switch between Bank it will also trigger a other Runsection, this way i can create a navigation screen on the LCD. and here a image how the controller looks like now.. and as you see i have the 10 buttons on the TOP of the controller. i like to have the same Function/CC note if switch bank... so if i'm on Bank 20 i can switch beteen bank 21,22,23,23,24,25,26 and 27 i need the same CC on bank 30 i can switch between bank 30,31,32 and 33 i need a other CC then on Bank 20~27 on bank 40 i can switch between bank 40,41,42 and 43 i need a other CC then on 20~27 and 30~33 if i can use more then one bank on a Event this will reduce the amount of events allot.. i only need to copy it 3 times instead of 16 times.. kind regards, Spirit
TK. Posted July 7, 2013 Posted July 7, 2013 Wow, you created a really sophisticated control surface! :smile: FFW requested a similar feature, therefore I had already a solution in my mind: the new .NGR command "set_active" Please try out this pre-release: http://www.ucapps.de/mios32/midibox_ng_v1_027_pre2.zip Here a demo configuration: http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=/trunk/apps/controllers/midibox_ng_v1/cfg/tests/multibnk.ngcand the appr. .NGR script: http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=/trunk/apps/controllers/midibox_ng_v1/cfg/tests/multibnk.ngr Receivers can't be put into a bank, because it's assumed that events should still be updated on incoming MIDI messages regardless if they are active or not. But you could try the .NGR command "set_lock" instead. A locked event won't receive messages -> exactly what you want. :smile: Best Regards, Thorsten.
Spirit Posted July 10, 2013 Author Posted July 10, 2013 (edited) hi and thanks for everything.. i uploaden V1_027 but i noticed something wrong.. on the .NGR i made a Startup sequence a tekst on the lcd and ALL leds goes on and Off after 5000mS. and after this i have EXEC_META RUNSECTION:1 EXEC_META SETBANK 4:4 But is doesnt RUNSECTION:1 anymore... before this worked perfect..? only if i press the button with Runsection:1 the Tekst from the .NGR pops-up... EDIT: i also notice the Led that should be ON goes ON perfect only i miss the tekst on the lcd.. so the Runsection command runs OK only i miss the LCD tekst.. /Spirit Edited July 11, 2013 by Spirit
Spirit Posted July 11, 2013 Author Posted July 11, 2013 oke nice i tried the new Bank feature and it works perfect!!! i got from 80% eventpool to 61% /spirit
