When I press sync( next to cc edit and play) the led doesn't light up. It displays bpm ...ect( like edit does when pressed).Did something
get reset?If so how do I remedy this?Everything  else on the mb6582 wilba operates just fine thanks for any insight on this matter ....----scottsober 7-12-2013
The LED is not assigned to a function anymore after we change the purpose of the "Sync" button (it switches to the BPM menu page as you noticed)
