sebiiksbcs Posted July 26, 2013 Posted July 26, 2013 (edited) Hey, I recently upgraded to v1.4e from v1.1. I used a PIC18F4620 I had lying around instead of the recommended PIC18F4685, and so far everything works just as well. Only the Wavetable sequencer seems to be broken. I can access and edit it in the menu, but it doesn't seem to have any effect. Could it be because I am using a PIC18F4620? Is anybody else using a an 18F4620? Any ideas? Edited July 26, 2013 by Akcija
TK. Posted July 27, 2013 Posted July 27, 2013 I never tried it with a PIC18F4620 by myself. Which setup file are you using? It would be especially helpful to know, if the WAVETABLES_IN_RAM switch is enabled or not, and how it works if you take the inverted value. Best Regards, Thorsten.
sebiiksbcs Posted July 27, 2013 Author Posted July 27, 2013 I'm using setup_pic18f4685_mbfm_v1.asm with settings adjusted to my hardware. I left all 4685-ish settings standard, which means WAVETABLES_IN_RAM is on, and also USE_SHADOW_BUFFERS and DISPLAY_CC_ASSIGNMENT_NAMES.... I'll try it with some of these settings off. Good idea! Interesting. When I set WAVETABLES_IN_RAM to 0, I get the following error during the build: ./src\mbfm_rnd.inc:410:Error [179] Unknown opcode "MBFM_RND_GenerateWTE_Loop" ./src\macros.h:15:Error [113] Symbol not previously defined (MBFM_RND_GenerateWT E_Loop). ./src\macros.h:15:Error [126] Argument out of range (-16377 not between -1024 an d 1023) make: *** [setup_pic18f4685_mbfm_v1.hex] Error 1 Does that mean the random generator needs WAVETABLES_IN_RAM to be on?
