maigre Posted July 27, 2013 Posted July 27, 2013 Hi! I'm working on a custom SeqV4 Frontpanel, and i plan to use the direct track buttons (with the switch on my GP encoders, and thanks to the BUTTON_DIRECT_TRACKx options) Would it be possible to have a LED_DIRECT_TRACKx also ? With this it would then be possible to remove GROUP / TRACK select part, to have only direct track selection and LED feedback... The reason is the 4 tracks per group is not corresponding to my synths config... For example my drum synth use 5/6 tracks... Maybe it's possible to use the already existing Group/Track leds with a sort of matrix connection ? But i'm not sure how to manage that... Thanks for your advices :) And i will post the FPD as soon as it looks good Best Regards, Thomas
John E. Finster Posted July 27, 2013 Posted July 27, 2013 Hi, I believe, there already is an option in the hardware config file to set this up. Look for: # OPTIONAL: individual track LEDs can optionally be assigned to SRs # they correspond with the BUTTON_DIRECT_TRACK* buttons TRACKS_DOUT_L_SR 0 TRACKS_DOUT_R_SR 0 inside the config file. my regards
