endernoumea Posted August 15, 2013 Report Posted August 15, 2013 (edited) Hello, I have two questions about this command : 1 - Is it possible to precise the type of hw_id in the meta command SetBankOfHwId ? I need it to change some encoders bank but my Dout matrix is receiving the instruction as well (which is not needed) In example something like : meta=SetBankOfHwId:ENC:14 .. to change only the bank of the encoder 14 ..or.. meta=SetBankOfHwId:ENC:any .. to change the bank of all the encoder and nothing else 2 - Second question, is it possible to change the bank of an item defined by a matrix ? If i use... meta=SetBankOfHwId:1001 ...to change the bank of my RGB matrix led event i have an error in MIOS studio like : ERROR: expecting 1 values for meta type in EVENT_BUTTON ... meta=SetBankOfHwId In other words: Is it possible to have a new instruction called SetBankfwd_id where we can use the same events like fwd_id ? :p Edited August 15, 2013 by endernoumea
TK. Posted August 15, 2013 Report Posted August 15, 2013 Hi, (note that I've no time to give explicit help till September) A .NGR script would give you much more control over the bank handling, especially the new "set_active" command. This is a beta feature, a precompiled binary (and some details) can be found in this thread: Hope this somehow helps (although it probably didn't answer your question) Best Regards, Thorsten.
