rmouneyres Posted September 2, 2013 Posted September 2, 2013 (edited) Hello, my employement company is destocking, i have an opportunity to have a lot fo EPROM for free : 27C010 27C020 27C512 from ST microelectronics, more than 100 units of each reference. and also SRAM chips Let me know rapidly if you are interested, so i decide to take them home or not. I will send them for postage costs only (shipping from FRANCE) until i have enough spare enveloppes to send them. Raphaël Edited September 2, 2013 by rmouneyres
C_04 Posted December 1, 2013 Posted December 1, 2013 (edited) Hi How much would cost me shipping to Poland? I would like to get them (eproms) but im not sure its worth it;) I need different ROM/RAM's for my devices. Now im using these old ones from motherboards - i buy them relatively cheap. But free is always better than that. Cheers C_04 Edited December 1, 2013 by C_04
rmouneyres Posted December 1, 2013 Author Posted December 1, 2013 hello, depending on how many you want price may vary. A dozen units would cost around 5€ in international simple letter I think. Tell me how many you want and i can tell you a more precise price. These are not intended to be for resale, but for personal projects.
C_04 Posted December 1, 2013 Posted December 1, 2013 Hi Thanks for reply. I may pick them all:). I thought You will send them in one small package. Of course im talking about private use. I have old DYNACORD P20 its a drum module. Ive designed cartridge and they have replaceable (or however) sockets for eeproms unfortunately right now only for 2764 but ill add there switches and will be possible to choose exact drum sound. So in 27512 there may be 64 voices but there will be necessary to use 2 binary switches. Its little complicate to reload single eprom UV erasable and thats why i use them a lot:). This module sounds '80s because its 8 bit machine 24kHz sampling frequency - hihats mostly are ugly or i should re-EQ them before use. Depends what SRAM you have - i would like to build a freaky 8 bit sampler. I also have idea to build something i called "stereoizer" but when ive tryied to simulate it - was closer to something like chorus. Basically its white noise slowed down to 20-100Hz (user may set it) which is controlling noise gate for separate 2 channels. Next step is a funny compressor with responses in eproms. Its for todays music to make this pumping sound but more controllable maybe like ADSR in synths. Envelopes will be like waveforms. A lot ideas but not so many ICs.:) Regards
rmouneyres Posted December 1, 2013 Author Posted December 1, 2013 Look like you have many projects going on. Be careful of the weight. Those little beasts are becoming heavy when numerous…depends on your budget. If you want many of them, i'll have to go for a packet instead of an envelope and the price is not the same (minimum 16€ for 1Kg maximum, 25€ for 5Kg). Here are the detailed references I have, on the right is the maximum quantity i can offer for one person. Please pick a selection, and send me a message. Eprom 27c512 qty 15 27c256 qte 5 27c010a qte 10 27c2001 qte 20 27c1001 qte 10 27c020 qte 10 SRAM Samsung K6T4008C1B qte 20 Japan SRM20100LC70 qte 2 M5M51008BP qte 2
C_04 Posted December 3, 2013 Posted December 3, 2013 (edited) Hi If i may i will pick them all. Especially these SRAMs 4MBit are what im looking for. Also often i use 27C256 and 27C512. 27C256 will be used in my druum module sth like TR909 im finishing now boards designing. Its my biggest project and it took me a lot of time. In fact i found some pics in internet of somebodys TR909 replica so it helps me a lot in drawing. But im thinking that there toms and clap + cowbell could be also in eproms because they not controllable (even pitch is constant). This SRAM K6T4008C1B is not pin compatible with another SRAM i need but if there 20 pcs i will redesign pcb even for stereo;) So how to contact You? Maybe via PM? Regards C_04 Greg Edited December 3, 2013 by C_04
C_04 Posted December 11, 2013 Posted December 11, 2013 Hi Today ive received package. Thanks a lot:) Regards and stay tuned C_04
