Aliã Bianco Posted September 16, 2013 Posted September 16, 2013 From http://mayhewlabs.com: Is possible? (i forgot almost everything about midibox in the past two years. sorry) http://mayhewlabs.com/products/rotary-encoder-led-ring thanks
ilmenator Posted September 16, 2013 Posted September 16, 2013 As far as I can see from the datasheet you'd need a software "driver" on the MIOS side of things for this to work properly. As the board is now, only the encoder will work without modifications, but not the LED ring.
