Midibox 16e
Antix
I am building a MB16e but it dont works yet.
I know that surely I made something wrong but I am not able to discover....
The last night nothing worked fine so at this point I decided to ask help to the forum.
These are the things I did:
Core8 with DINx4 connected at J6 for the 16 encoders ( as I see in this diagram:       http://www.ucapps.de/mbhp/mbhp_dinx4_16enc.pdf )
                  DINx1 connected at J9 for the 8 switches
I uploaded with Mios Studio the "setup_midibox16e_without_ledrings.hex" without any modify ( I left the the "mios_enc_table" as is because I believed that was enough using the setup.....asm )
so the switches works fine but the encoders give no signs of life
Before I tell you of the other problem I had it is better have an answer about this:
is it right to connect the DINx4 for the encoders to J6 instead of J9  ( or better : have I understood well the diagram ?)
Have I anyway to modify "mios_enc_table.inc" to enable the encoders?
Thanks for any help
Antonio
P.S.
I apologise for the newbe question
Shouldn't you connect the DIN1x for switches to J9 and then the DINX4 for the encoders to the DINX1 from the switches? Just as it says in the comment of the pdf you linked to.
Just like in this picture, just leave out the led and ledrings. mbhp_midibox64e.gif
Edited by Shuriken
Hi Shuriken,
Thanks for your reply
I followed  the diagram http://www.ucapps.de/mbhp/mbhp_dinx4_16enc.pdf
where I read that it is the right connection of the encoders for Midibox16e
Anyway I can connect the boards in this other way and make my tests
Probably I have some problem with Toolchain too
thanks and regards
Antonio
Hi Shuriken,
The pdf says:
MIOS based controllers: just chain it with the DINX4 button modules @J9!!! :wink:
I edited the picture to show you what i mean.
post-6528-0-91683400-1381664810_thumb.jp
Edited by Shuriken
Ok,
I will connect like this then I will understand if I have problems with toolchain for recompiling.
I think that I havent understood well about the application:
I have to write in the mios_enc_table  the encoders I am using or the setup will do it for me?
If I have to modify the table I am in trouble then because seems that my toolchain dont works fine.
Anyway I will put my condition as the shematic you show me then will face any new difficulties,
Thanks and best regards
