yodabe Posted November 10, 2013 Posted November 10, 2013 hi, how to change the sr pinout for the accent 1 and 2 ? i need to attribute the accent output to sr 11 pin 0-1 but i see nothing into the setup_808_default.asm about the accent2 ... best regards
TK. Posted November 10, 2013 Posted November 10, 2013 Hi, there is'nt a second accent... Where did you find informations about "accent 2", maybe you mean something else? Best Regards, Thorsten.
yodabe Posted November 10, 2013 Author Posted November 10, 2013 . Where did you find informations about "accent 2" on MB-808 Revision 3 Shift Register Pins ==> http://www.eight-oh-eight.org/Rev3/shiftregistersrev3.html
TK. Posted November 10, 2013 Posted November 10, 2013 Ok... this one is new to me, at least it isn't officially supported. However, you can use any track to generate accent pulses. E.g. you could use Track 15 (by default assigned to "Ext3") for this purpose, just specify the right SR and pin number. Best Regards, Thorsten.
yodabe Posted November 10, 2013 Author Posted November 10, 2013 Ok... this one is new to me, at least it isn't officially supported. However, you can use any track to generate accent pulses. E.g. you could use Track 15 (by default assigned to "Ext3") for this purpose, just specify the right SR and pin number. Best Regards, Thorsten. ok thanks but i'm confused with the accent part on my 808 clone maybe you can help me If I have understood correctly the 808 accent shematics i need 2 triggers for triggering the accent voltage but when i connect 2 triggers i got no sound with only one trigger (accent1 in)i have sound but not accent and the accent pot give a volume control ... do you have an idea of the problem.?
yodabe Posted November 12, 2013 Author Posted November 12, 2013 ok i find the way mb accent trigger output to ==> tr-808 accent1 in tr-808 accent2 in ==> connected to the gnd ! 1
